Quick a/c question....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddin4fun, May 24, 2001.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Can I fix an evaporator or is it better being replaced? Also, when I fix/replace it, do I have to get the whole thing reworked in order for it to cool properly and not tear up the compressor?
    And just where the hell is the evaporator (I was told that's what was wrong with the a/c)?????? I know just about nothing about a/c! [​IMG]
    Oh, '79 blazer with 350 if that info is important. [​IMG]
    Imagine a cowgirl twirling a rope.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Without gettng too technical, the evaporator is the coil that the fan (inside the truck) blows air across. This is how you get cool air in the cab. You would be better replacing it. Not something you want to do twice. It is located in the engine compartment and kind of inside the truck. Just trace the refrigerant lines to where they go into the firewall. It is prob. behind a cover in the engine compartment.
    You should make sure you have the system vacummed down and recharged after replacement.
    My .02
    John
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '84 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD w/8.1L & Allsion Auto
  3. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    So I can replace the evaporator and have a/c without replacing the condenser and such? Cool!!!
  4. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    When i did my A/C this past month i had to go through the whole system. My evaporator was cut at the line so i also needed a new one. So i went to the junk yard and found several still in the box on the firewall so it was protected not just laying in the dirt;(if you get one fromt he junkyard look at the coils because if they look wet with dirt stuck to them it has a leak and you don't want that) I installed it and works fine, i cleaned it up with coil cleaner or degreaser and then compressed air and blew nitrogen through (my dads an A/C guy so i had all the stuff available to me, compressed air should work also) The evaporator is located in the black box on the firewall near your blower motor and the heater hoses.
    hope this helps.
    [image]http://www.users.qwest.net/~adamfam/dance.gif[/image] [​IMG]<P ID="edit"><FONT SIZE=-1>Edited by Impex on 05/24/01 11:45 AM (server time).</FONT></P>
  5. Impex
    469
    Chandler, AZ
    Also you should replace the accumulator / receiver dryer and orifice tube because there is a good chance
    its full of junk and will help flow better.
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Most GM evaporators can't be repaired, so you'll have to get a new one. After replacing it, I'd put in the R134A conversion, so you won't have to mortgage the farm to get it charged again.
    I have voluntarily axed "Pancho" in a bandwidth conservation effort [​IMG]
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    If you use air to blow it out, make sure there's a dryer/oil trap in the line.
  8. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Lara, I'll send you the A/C evaporator unit off of Stampy. I'm not going to run A/C. I'm sure its in good shape. I'll just send the whole heater/A/C box...
    Rene...got a soft top and don't need A/C
    <font color=red>If at first you don't succeed...skydiving ain't for you!</font color=red>
  9. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Whoa!!!! Cool!!!!! How much you want for it!
    Can I just replace that and be good to go, for real?
    I'm so used to repairs costing an arm and a leg!
    This seems too easy!
    Thanks Rene!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  10. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    AFAIK, you can just bolt this one up and have the system recharged.
    As for $ I'll ship it first and let you know...if the shipping isn't too much just forget about it! Now that I've actually been in the Ft. Worth and Dallas area I know for a fact you need the AC more than I do![​IMG]
    Rene
  11. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    I know nothing about a/c allthough since my a/c doesn't work I would like to learn :). What is this R134a conversion your talking about? Cheaper recharge? And finally where would i get it, how do you do it, how much does it cost, and should i do it or have it done?
    1982 6.2L Diesel K5 Blazer, TH700, 31 inch tires.
    Fire ALWAYS makes it better.
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    <blockquote><font size=1>In reply to:</font><hr>
    <hr></blockquote>
    Ha! It ain't even summer there yet! It's just starting to get warm there... [​IMG]
  13. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    105 is nothing for us here.
    I'm sure someone from AZ will come by and say they hit 120 regularly, but here it's not "dry heat"! [​IMG]
  14. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    I stopped at a rest stop just to change clothes near Ft. Worth...I could have wrung out my shirt it was so humid and hot![​IMG] As for extremes, I also had snow going over the pass in Wyoming...
    Rene...enjoying a mild late spring Pacific Northwest day!
