Quick ? about np205
Discussion in 'The Garage' started by Chrisblazzer89, Apr 17, 2007.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Ok I now have a 700r4 with an np208 is it possible to swap in an Np205?
    What will I need to do to make this work?
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Yeah it's doable. IIRC need a 350/205 adaptor and either swap the 700 output or cut the excess off. Dunno bout spacers....
  3. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    you will need a 1" spacer from www.automatickings.com 80$ US and then the 205 needs to be from a th350 27spline
  4. chosen(1)
    chosen(1) 1/2 ton status
    Nov 19, 2002
    206
    Michigan
    I just did this swap. Here is what you need:
    205 from a th-350 (27 spline)
    factory 350-to-205 adapter
    shifter (I went to a twin stick)
    27 spline coupler sleeve
    flat style crossmember and mounts
    Spacer Kit http://www.transmissionpartsusa.com/Quick_Swap_switch_kit_700_to_350_4x4_p/609-00007q35a.html about $55
    I had to have my front shaft shortened and a new rear shaft made.
    You will also have to cut about 3/8" off of your output shaft. (go slow don't get it too hot. It is hardened and you don't want to take out the temper)
    -I think that's it.
    One tip I can give you is make new studs. Don't use the ones with the kit. They were too short for me. I made new ones about an inch longer and it made it alot easier.
  5. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    Any ideas on clocking the 205?
