Quick alt. question(UPDATE*FIXED*)
Discussion in 'The Garage' started by BobK, Feb 16, 2004.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    71 Blazer with a 140 amp 3 wire alt.
    Noticed my lights are REAL bright and my amp gauge is peged to full charge when I'm on the gas(right in the middle at idle).
    It's prob. the voltage reg. right?
    I have'nt taken any reading with my digital volt meter yet as it's dark out now.
    I Just wanted to get some opinions before I statred to diagnose tomorrow.
    Thanks in advance. /forums/images/graemlins/peace.gif
  2. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Re: Quick alt. question
    I think your on target there.
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Took some reading with my volt meter this morning...21 volts at idle /forums/images/graemlins/yikes.gif
    Well,had to go to 3 different parts stores to get it checked and even then they told me it was toast.It wasn't toast....I replaced the regulator and all is good.
    14.3 volts at low idle with heater on high,high beams on,55wt driving lights on, stereo on,and windshield wipers on. /forums/images/graemlins/grin.gif
    Sorry to any parts guys on the board but boy are most of them idiots
  4. dyeager535
    26,982
    191
    What kind of alternator is it? Aftermarket or stock application?
    With that kind of output at idle, sounds like an aftermarket of some type to me.
    All the posts lately of alternators, if someone is looking for something specific, more details about alternators used can always help.
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Ya it's a Summit brand 140 amp alt.It's actually made by PowerMaster.
    Summit sell's it as a one wire alt. but according to PowerMaster(I called them) if you remove the rubber plug that blocks off the 2 prongs that the factory alt.'s use it can be used as a 3 wire alt.
    They test them before they leave the factory and it comes with the test info. attached to the alt.
    Mine was 90 amps at idle and 163 at highway speeds. /forums/images/graemlins/thumb.gif
    Oh ya,I had my two 14" electric fans going as well.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You still have the 140A alt run through the stock ammeter? I have heard that that isn't a good idea with anything over the 35A stock alt. I will be ditching mine (in favor of a voltmeter) as soon as I put in my 135A alt.
  7. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Mine caught fire with the stock alt.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    All of this is why I don't use an ammeter.
  9. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Yup.I've had the factory ammeter working since I got the truck(5 years ago).No fires,although I did replace the circiut board in the back of the gauge panel when I got the truck.
    I thought the factory amp. gauge only measured charge or discharge conditions,not actual amps. /forums/images/graemlins/confused.gif
    Anyhow the gauge works well.I've rewired my truck and am confident that that gauge does NOT see anything near the amperage I mentioned.
    One end from the gauge to the alt. and the other side of the gauge to the battery.
    If that samll 18g ammeter wire was actually accepting or carrying the full 90-140 amps that thin 18g wire would burn up before catching the gauge on fire....you'd think.
  10. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    I got this from MAD Electrical's site.
    Our amp gauges are "shunt type" they don't carry the full amp loads of older systems.
    GM also up-graded their system long before the Dodge Boys. When GM introduced the alternator with ’63 models, it was controlled by a more complicated but more efficient voltage regulator system. And the new GM system could support a warning light at the dash. The warning light was often standard equipment and the gauge was an option. GM vehicles built with the gauge option also had a more modern design of AMP gauge at the dash. The newer AMP gauge was a remote shunt type design–a length of the battery charging wire in the under-hood harness served as the shunt. The dash gauge and related wiring no longer handled heavy current load. Same with Ford in ’65 and newer model cars–the Ford system could work with a warning light at the dash, and cars that came dash gauges had a remote shunt type amp gauge.
  11. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    All of this is why i plan to use a secondary alternator dedicated specifically to all the aftermarket mods, lights,fans,amplifiers, whatever, and keep all factory items using stock factory hardware, no guessing, no worrying. WOOP WOOP
    /forums/images/graemlins/pimp1.gif/forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/pimp1.gif
