Quick and easy way to *lower* compression?
Discussion in 'The Garage' started by Pookster, Nov 12, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    if you were trying to lower the compression of an engine, can you use some kinda head gasket spacer? Just thinking that people deck a block to get better compression, thinking that it could be done in reverse?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No. That will destroy your quench and give you worse detonation than you have now.
    A bigger cam or changing your cam timing is probably a better option.
  3. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    its for a diesel. /forums/images/graemlins/wink.gif I want detonation!
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Oh, damn.
    I'd imagine it'd work...not sure that quench appies to Diesels.
    How about polishing those cylinder heads while they're off?
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    its just a thought- Since nobody seems to make low compression heads for the 6.2 diesel, why not just make a bolt on spacer, kinda like a TBI spacer.
    Im sure im missing something important, but... its just a thought...
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    ok, But why would you want to lower the compression?
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    for a turbo.
    you want the better pistons so spend the money for the 16:1 s
    deep dish makes more power then a flattop
    more surface area for the constant pressure
  8. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    I've heard of spacers and guys using double head gaskets,on gas motors--but never on a diesel!.I doubt if double gaskets would live on a diesel,especially with a turbo!. /forums/images/graemlins/crazy.gif
  9. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Diesel's typically run 20:1 CR even with a Turbo. If you really need to increase CR, go with a composition head gasket (thicker than steel or copper). If this is not enough than you'll need to swap pistions or heads.
  10. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    thats only the older diesels or the NA diesels. I think the cummins, duramax and powerstroke are all now like 18:1 or lower.
  11. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    If there is any meat to the combustion area of the cylinder head? You could remove material kinda like when they CC heads.
    Pistons could also be fly cut to remove material but at what expense IE: blowing a hole in the top of the piston.
    The engine would not produce much power down low till the boost came up,,maybe some web pages on tractor pullers might be a good place to look,,,those diesel powered pullers make some insane boost with 4 or more turbo's /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
