Quick Brake Question
Discussion in 'The Garage' started by daleearnhardt01, Dec 12, 2003.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Hey yall, gettin ready to take my math final /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif but after Im goin to go look at a buddies 86 P/U. He said the brake pedal goes right to the floor. Im thinkin the MC is gone. Just want some other ideas and stuff to check. /forums/images/graemlins/thumb.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Sounds like the MC to me
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Assuming he has lining left on his brakes, he could have a popped rear brake cyl, caliper, or line. I had a rear cyl fail once. Otherwise, sounds like MC.
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Alright, I drove the thing and here's the rundown: The brakes come and go, sometimes good sometimes bad. Sometimes pumpin them works, other times it didnt. Called a co-worker back home at the shop just to confirm that it would prob be the MC and went a got one from Advance. Anything special I need to know when Im puttin it on, tricks/procedure wise?
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    sounds like a master..remove the old master, install the new one, bleed the master, then bleed the lines..starting with the rr, then lr, then rf, then lf..bleed each one REALLY WELL /forums/images/graemlins/thumb.gif
  6. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Should I bench bleed the master or just do it on the truck?
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    no, any poppage won't lose pedal pressure- little thing called a proportioning valve /forums/images/graemlins/laugh.gif i ran with no rear brakes- open lines, for a month (1-2 miles at a time.)
