*quick*caliper grinding question. like to have it done tonight,
Discussion in 'The Garage' started by ducttape114, Mar 10, 2003.
  1. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    how much clearence is needed between the caliper and the rim? right now i have about 1/32" all around. i seem to have a low spot in one rim cuz it still just barely touches. anyways, i DID do a serch and quickly scaned Russ's tech artical. so if i missed somthing please dont yell at me. thanks in advance
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I brought it down to about 1/16" and haven't had any contact from rim flex yet. Dana60 with 3.5" backspaced 15x10.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I just ground mine till it didn't scuff anywhere on the primered surface. It's pretty much impossible to figure exactly how much clearance there is up under the rim... Good luck...
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Oh, and make sure that is with the lugs on and torqued...
  5. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    thanks for the quick replys guys!!!!!!
  6. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    agreed... if the thing clears fine with the rim torqued down ur a-ok. Always keep in mind that if you ever have to put new rotors/pads on ur rig, you may have to grind more. The caliper thingy pulls in as the pad wears so it gets easier to clear the more worn your stuff is. any1 who really knows stuff about brakes could prolly explain this better than me... lol! /forums/images/graemlins/grin.gif
    j
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I took a piece of 120 grit sand paper that was folded in quarters, held it to the rim and span the rim around. Wherever the primer I put on the caliper was sanded was a high spot that I knocked down. I did most of my "Grinding" with a file
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The "use new brake pads" thing is in the artical too... /forums/images/graemlins/laugh.gif
