Quick caliper ?
Discussion in 'The Garage' started by fabjunkie, Aug 16, 2006.
  1. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    I've been through all the threads on the issue, but have not come to a conclusion on this. For the 14ff disc swap, are the calipers for a D44 or 10-bolt? Do D44 and 10-bolt use the same calipers?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    I got mine for a 76 3/4t d44. I am unsure of the difference, but that's what I got. My kit is from DIY4X.
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    The only difference between d44 and 10b is the brake line bolt. 7/16 or 10mm respectively
  4. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    there is also a slight difference in the casting of the caliper body which relates to what position the brakeline fitting will be at or can be at.
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    either one will work as far as I know half tons work too. Looked up the part numbers at a car quest and they were all the same
