Quick cam-swap question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by heavy4x4, Feb 22, 2004.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Obviously the radiator needs to come out, but is there enough room to leave the AC condensor in and still get the cam out past the front of the block?
    350 TBI in a 1990 Suburban.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I have never put a cam into an air conditioned vehicle. I would assume the condenser can be angled enough if it is in the way.
    Which cam are you swapping in? Keep me posted on the results, since our rigs are very similar. /forums/images/graemlins/waytogo.gif
  3. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    When I swapped the cam on my 89 K5, it just barely made it without taking out the condenser. The real problem was in the center support. I found that cutting out the support with a sawzall fixed that, though.
  4. alaskanbowtie
    alaskanbowtie 1/2 ton status
    Feb 15, 2004
    112
    ALASKA
    a little friendly persuasion with the support and it will go but I didn't have to cut mine out, if you do it would be an easy piece to weld back in. good luck /forums/images/graemlins/waytogo.gif
  5. heavy4x4
    Aug 28, 2002
    3,270
    NerdBoy and Alaskanbowtie, that's EXACTLY what I wanted to hear...thanks!
    Subfan, this modification probably won't come until this summer (if it does at all - I'm really debating how many "in-between" steps I want to make "throwing my money away" before I can really build my truck they way I want it in 2 or 3 years). But, I may give Comp Cams a call and see what they suggest. And, I'll for sure let you know/post up how everything turns out.
    Is anybody here running a mild performance cam in their 350 TBI? Something that is computer friendly, passes emissions, and has some low-end grunt? If so, post up what you've got and how you like it, please. /forums/images/graemlins/thumb.gif
