Quick change rearend
Discussion in 'The Garage' started by dmanblazer, Apr 10, 2006.
  1. dmanblazer
    dmanblazer 1/2 ton status
    Sep 5, 2004
    165
    Wellington, Kansas
    Has anyone ever thought of using or tried to use a quick change rearend in their rig? Would it be to weak or what? The Raminator monster truck uses a type of quick change in it, though it's much larger. But just think of it, going from highway gears to wheelin' gears within 5 minutes or so.
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thought about, would love it! Dont know how fesable it is. Isn't the 9 inch real strong and have quick change capabilities?
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    An important question: How much would such a setup cost, and do you have that amount in your budget?
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    isn't raminator running a zf axle with planetaries like everyone else in monster trucks? You could drop the center section on that or change the planetary gears but neither operation would be nearly "quick change". What I've always been told about quick changes is this, they are loud(straight cut gears) and there is more slop in them then you would really want for a street driving vehicle. That said, have you ever looked at a quick change? The actual quick change unit sticks a good I'd say about 8" back past the axle centerline, is made of magnesium or aluminum and if you rotated your pinion like you would need for a lifted truck, say good bye to the gear case really quick. If you REALLY want this option, I'd go 9" Ford route converted to say Dana 60 spindles and full floater. Likely cost less, and be a much higher clearance option.
    Quick change rears are strong, and great for their purpose(mostly circle track racing, where you are at a different track all the time or changing for track conditions, thats where I have my very limited experience with them).
    If used in a front application, you';d have that same big magnesium/aluminum chunk sticking out in front of your axle, not cool imo.
    www.wintersperformance.com if you want to look into them.
    here is a center from a Winters quick change:
    notice the pinion enters well below axle centerline, no where near a good idea for off road use. It would be sweet if you could flip it over, but it would then turn the wrong direction.
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i saw a on extreme4x4 that monster trucks use quick change transfer cases not axles
  6. dmanblazer
    Sep 5, 2004
    165
    Wellington, Kansas
    Well I work for Halibrand Performance and was just wondering. I could save alot of money just by working there (wheels, air ride suspension, rearends, exhaust ect.)
