Quick Crew-Cab/Suburban question, and Bogger picture request...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by heavy4x4, Feb 3, 2004.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Real quick question: a Crew-Cab cab will bolt up to where a Suburban tub was, correct?
    Picture request: 38.5x 11 " boggers...preferrably mounted on a truck.
    The ideas are formulating. /forums/images/graemlins/grin.gif /forums/images/graemlins/waytogo.gif
  2. Grim-Reaper
    7,385
    Atlanta
    Re: Quick Crew-Cab/Suburban question, and picture request...
    Rear most cab mounts might be a issue. I have looked at this and yes it's doable BUT you might have to move the rear axle back a little to help on clearence on the rear of the cab. It will be a build it and see. I say screw a real truck bed and go with a flat bed with a fuel cell tucked up behind the cab and chop it off at the shackle mounts. /forums/images/graemlins/peace.gif
  3. heavy4x4
    Aug 28, 2002
    3,270
    Actually, I didn't mention it, but that's exactly what I had in mind. But, the frame will be hacked off after the rear axle (4-link). And, with the 4-link I'll be able to move the axle back if the cab gets in the way. Oh, and the bed won't exactly be a flat-bed, but rather a combination of flat-bed and storage compartments (probably end up being as tall as a regular bed). /forums/images/graemlins/peace.gif
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well you are thinking of what I am doing, except I am putting the crew cab on a regular cab longbed 1ton frame.
    I will need to do some relocating of the body mounts since the frame goes up behind the regular cab but I have that all figured out, and I will have a crew cab on 131" wheel base instead of 168".
    And the rear will be a utility/storage bed with an unfold tent pad. /forums/images/graemlins/peace.gif
    I should be gettign the cab soon and the frame is ready and stripped so as soon as I get the cab I will start the procedure and document it with pics.
    /forums/images/graemlins/whistling.gif
  5. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Uh oh...... /forums/images/graemlins/thinking.gif
    Thinking of ditching the burb, or building a wheeling only truck? /forums/images/graemlins/waytogo.gif
  6. heavy4x4
    Aug 28, 2002
    3,270
    /forums/images/graemlins/shocked.gif You caught me...
    Actually, this idea is for maybe 2 years down the road when I'm out of school and have a daily-driver. It won't exactly be like I'm ditching the 'burb because it will be my current burb frame, interior, front clip, and 14 bolt. And, it will be a trail-only rig, so I'll have to get a 2500 HD to tow it. /forums/images/graemlins/pimp1.gif
    Right now it's all just ideas and dreams...I'm just thinking that with the only place to wheel near us being 200 miles away, it makes sense to have a trail-rig...that way you can REALLY wheel it and not have to worry about it getting you home. /forums/images/graemlins/waytogo.gif
  7. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Then by then hopefully I will have mine done and let you know of the problems.
    /forums/images/graemlins/thumb.gif
  8. heavy4x4
    Aug 28, 2002
    3,270
    /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif
  9. heavy4x4
    Aug 28, 2002
    3,270
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why coils in the rear and leaves up front?
  11. heavy4x4
    Aug 28, 2002
    3,270
    I dunno really...that's just kinda what I decided when I was drawing it. I'm sure that at some point it would turn into a coil suspension front, but for initial building ease/cost, it would be leaf springs. /forums/images/graemlins/waytogo.gif
  12. T-ROY
    T-ROY 1/2 ton status
    Dec 3, 2002
    468
    Orchards, Wa
    If you are going to get really out of control, build your own frame out of semi truck frame rail and mount rocks with 1600/20's. Trail rig or not, people would have to look. I'm considering doing just that with a 74 Blazer that I was given. I used to work for Freightliner and could get the framerail cut-offs. I build bumpers out of them right now. The material is 10" face "C" channel that measures 1/4" thick. Then you can mount axles and drivetrain anywhere you want. It ends up being a 5" body lift without the problems of body lifts. I'm thinking along the lines of a 5.9 Cummins Turbo Diesel with an Allison auto trans and a NP205 doubler. Might be a little rediculas, but it would be cool.
    T-roy
