quick d60 carrier question
Discussion in 'The Garage' started by protechk5, Apr 29, 2007.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    I need to replace the axle seals on my front dana 60, its ok to pull the carrier out, right? I just make sure to put the bolts and bearing caps in the same spot, right? Also what do I torque the bearing caps back to? Thanks
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes it is ok to just pull the carrier just make sure you keep every thing in the correct order, and after your done it would be a good idea to run the pattern just to be sure everything is ok
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The torque on the carrier cap bolts is 80lbs.
    Backlash is .005"-.009"
  4. protechk5
    Sep 26, 2004
    2,015
    VA
    ok thanks alot
