Quick-disconnectors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MR.4x4, Aug 1, 2002.
  1. MR.4x4
    MR.4x4 Registered Member
    Jul 17, 2002
    66
    Hi, i want to make my own Quickdisconectors for the antisway bar, has anyone made them??
    Who has some photoes??
    Thanks for your help
    I want to put them in the front of my 75 Blazer -k5-
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I did /forums/images/icons/grin.gif
  3. MR.4x4
    Jul 17, 2002
    66
    WOW!!
    I love your flex!!!
    Wat else you did for the Flex??
    Can you tell me wat did you bought to make the disconectors???
    Thanks again!!
  4. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I did a slow but permanent disconnect on mine.
  5. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Thanks /forums/images/icons/grin.gif
    Iv got Pro Comp front springs With the tops of the clamps cut off and Pro Comp shocks (that are too short).In the rear I have F150 springs with Marv Springer shackle flip brackets and Rancho 5112s.
    As for materials I used 1.75"x.140"pipe(measures 2"OD),2"x.25"flat bar,2"round Delrin (in place of poly bushings)turned to the ID of the 2" pipe and pressed into it,and a piece of round stock for the spacer that the bolt goes through.I got the pins at Ace Hardware.
