QUICK fellas... D60 vs. 14BFF rear axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jun 1, 2001.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Please! I need to know which one to stay with! I am trying to negotiate a trade, and I want to make sure that trading the 14BFF for a D60 rear is a good call... Thanks again guys and gals!
    <font color=red> Check out my truck @ </font color=red>
    <A target="_blank" HREF=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</A> [​IMG]
  2. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I may be wrong, but I thought a D60 was primarily a front axle? I always figured if you had a 14bolt rear, you used a d60 up front.
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The 60 rear is weaker than the 14-bolt, but you'll get better clearance under the diff. The 60 is also quite a bit lighter.
  4. Cliffy
    Cliffy Registered Member
    Oct 8, 2000
    99
    South Lakewood, CO....... FINALLY!!!
    I'd stick with the 14FF. I know the D60 has better ground clearance, but I've seen too many people sucessfully shave the FF-ing pig and not have any problems. STICK WITH THE FF-14bolt.
    Besides detroit lockers are cheaper for 14 bolts.
    Coil sprung 71 blazer.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    I second what Harry said! I believe there are more locker and gear choices for the D60 though, but the lockers for the 60 are more expensive.
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  6. Cliffy
    Oct 8, 2000
    99
    The rear D60 is a popular rear axle choice for wheelers with Jeeps and Scouts (and other smaller vehicles) since they often don't need the brute strength of the 14 bolt. (I like the security of knowing I'll NEVER break an axle shaft in my big ass rig)
    They can be often be found in Dodges and fords and occassionally a chevy.
  7. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    So damn... OK I keep the 14BFF... but then where can I get a 4.10 gear for the d@mn thing?
  8. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I also am powering my truck with a strong modified 454... ~500HP
    I just don't know how long it will take to convince the wife to let me buy the new ring and pinion set for the 14BFF!
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Check out <A target="_blank" HREF=http://www.reiderracing.com>http://www.reiderracing.com</A>. Great prices and great service!
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The 14-bolt FF definitely has a strength advantage over the Dana 60, but that doesn't mean the 60 is weak by any means at all. A guy in our club has been running a FF Dana 60 rear with a Detroit in a hybrid Toyota truck with a small block and 36" tires for a while now with no problems.
    The 60 has the advantage of lighter weight and better clearance, the downside is that modifcations are needed to fit it under your Blazer (spring pads and shock mounts moved, etc..).
    The advantage of the 14-bolt are price (plus Detroits are "only" around $300 vs. $500+ for most other applications), they are easy to work on, and are very easy to find parts for in a junkyard. On that note, you could probably find a set of 4.10 gears out of a junkyard axle relatively easy.
  11. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    ok... I have an open 8-lug 10-bolt in front now. Do I have to worry about it if I am going to be lead-footed with 35x12.5" tires?
  12. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    With the motor you specified and the gearing/tires I'd look at upgrading the front axle to a D60. If you had a 350cid then you'd be fine with the 10 bolt IMHO.
    Crawlin the rocks with my K5
    <A target="_blank" HREF=http://www.rockreadyk5.com>http://www.rockreadyk5.com</A>
  13. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I have a Dana60SF rear and so far it has been one helluv a rear axel. Never owned a 14FF so can't really give you a acurate comparison. I think eather one has more than enough strength to hold up under our rigs so ......
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  14. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    In my opinion, driving with a "lead-foot" on the trails with 35" tires will at some time cause a failure of the front 10-bolt.....but a lot of it depends on what type of terrain you run on. Running straight through mud holes usually isn't too hard on stuff, but crawling around on rocks and deep ruts can cause problems. I've broken my front 10-bolt (front axle shaft u-joints) a couple of times, and both times at less than 1/2 throttle.
