Quick gas cap question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 72yellow, Apr 6, 2003.
  1. 72yellow
    72yellow Registered Member
    Feb 24, 2003
    13
    Connecticut
    Would not having a gas cap cause dieseling? I was driving around and it was running fine, got gas and forgot to put the cap on, long story with the computers at the gas station ending with me being pissed and forgetting cap. After that it seemed to be dieseling. I'm not sure if it has the emmisions or not.
    Also check out some pics at http://members.cox.net/72blazer/
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I wouldn't think that would cause the problem. Did you get cheep gas? When you put a new cap on did it fix the problem?
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I don't think missing a cap would make it diesel. Where is Your Idle set at? Do You have to run Oxygenated fuel in the winter? and then back to "Good" /forums/images/graemlins/rotfl.gif gas in the spring? /forums/images/graemlins/grin.gif
  4. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    Removing the gas cap "depressurizes" your fuel system, but should not cause dieseling. You prob. got some bad gas. Try throwing some Heet or other good gas line "antifreeze" in your tank.
  5. 72yellow
    Feb 24, 2003
    13
    Connecticut
    I was thinking it might be bad gas, i also ran the tank down so there might be junk in it. I'll blow out the carb this week and put some good gas in.
