Quick help!?! Diesel crew..
Discussion in 'The Garage' started by 82K5_6.5L, Nov 5, 2006.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    so im replacing the damn injector pump on the blazer, but i am hung up on getting 2 of the lines off the pump itself. they are the 2 on the bottom of the pump that sit almost right ontop of the block. its killing me! any special tools i should be using besides an open end 5/8 wrench?? any ideas?
    :confused:
    thanks guys
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Undo those lines from the injectors, then pull the IP and those two lines out as an assembly. Once it's out those two will be easier to get to.
    Rene
  3. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I managed to get mine shoved back in with the lines attached still. wasn't pretty, lots of cursing and shoving required. I looks like it came out the same way too, from the way the lines were bent
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    ^^^Pay attention to this guy, he's a pretty fart smeller:D
  5. jdemaris
    jdemaris Registered Member
    Apr 10, 2001
    76
    Offset angle wrenchs will do it. They used to be expensive since Mac and Snap-On were the only places selling them - but now you can buy a whole Chinese set from Harbor Freight for $19, whereas one wrench used to cost $30 from Snap-On.
    Also, a 12 point flare-nut wrench works well -but sometimes you need to bend it a little. I keep two in my diesel tool box - with different angle bends on the handles.
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    FWIW, I've used 12pt crow's-foot wrenches(?) on a 3/8" ratchet & extension to tighten up leaky lines.
  7. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    x2. it would be easier to reinstall it by having all the lines hooked up to the pump before you place it in the valley anyway...
  8. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    I use crowfoot line wrenches myself. leaving the lines attached seems pretty easy also.
  9. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    ive already got 6 of the 8 off without taking the lines all off. those were pretty easy, but i think im going to have to take these last 2 lines off to get the pump off. what a pain in the ass!!!
