QUICK HELP NEEDED!! what is it?
Discussion in 'The Garage' started by spongeidys, Aug 17, 2006.
  1. spongeidys
    spongeidys 1/2 ton status
    Jul 6, 2005
    2,566
    Dillion, CO and Palmerton, PA
    we're redoing the brakeline on my truck that runs to the rear brakes. when we got to the back, we noticed this junction tying two lines together, but to me, it would seem easier just to bypass that because it doesnt seem to be doing anything other than tying those two lines together. so, do i have to run the lines in and out of the junction, or can i just bypass it and run one line straight back?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I believe that adjusts the amount of fluid flow to the rear brakes based on load and trailer weight .
  3. dyeager535
    26,979
    Correct :)
  4. spongeidys
    Jul 6, 2005
    2,566
    so if im not gonna be towing any trailers is it needed?
  5. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,548
    16
    Anchorage, AK
    Specifically, that is a load sensing proportioning valve. It allows more or less fluid to the rear brakes based upon the ride-height of the rear of the vehicle. Higher=less fluid=less braking from the rear=lower likelihood of rear wheel lockup. Lower=more fluid=more braking from the rear=all four wheels braking to help slow/stop a heavy load.
