Quick help please! 14bolt gear change question
Discussion in 'The Garage' started by jakeslim, Aug 10, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    I took all both bearing races and can not get the differential to fall out. Do I pry it out? Am I missing
    something? It seems that the bearings are holding it back from sliding out.
    Please,need quick help and much appreciated!
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    it should come out with a good yank...are the axles out?
  3. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    i pulled the axles out. It seems like the edges of the bearings are getting caught in that part with holes in it(the one the bearing race pins go into) I am afraid if I pry i will break something. Its getting dark and I would like to pull it before I finish for the evening!
    any ideas. should I push the axles in and see if I can get it to release?
  4. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Back off the adjusting rings and then the diff shoud all out.
  5. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    ok, I figured it out(yep the adjusting rings) needed to be turned. I did not know they turned. Now I do. I guess that is why we try these things on our own instead of paying someone else.
    Thanks for the help.
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Right on dude. /forums/images/graemlins/thumb.gif
    This is exactly the kinda stuff I like to hear about. Not bein afraid to dive into to a project even if ya have no idea whats involved. Thats the way I learned to do pretty much everything as far as trucks and stuff go. Best way to learn I think.
    On a side note- I've probably taken the carrier out of 10+ different 14b's, the last time I did it, I couldn't get the carrier out either...I scratched my head, pushed, pryed, pulled, hammered....Wouldn't move. Then I rested my hands on the hub, and felt the bolts that still held the axle shafts in..
    /forums/images/graemlins/crazy.gif duh. I looked around to see if anyone noticed, I wasn't that lucky. Gokartergo noticed...lol. /forums/images/graemlins/thumb.gif
