quick help. truck wont shut off, ***update***
Discussion in 'The Garage' started by gonger, Apr 29, 2006.
  1. gonger
    gonger Registered Member
    Nov 8, 2004
    42
    1989 suburban, trucks sitting in driveway runnning as I type, I shut off ignitition and it keeps running, Is there a relays switch anywhere, when I turn key off, all accessories/ac do turn off, making me think theres a relay?
    thanks in advance for any tips.:bow:
    update....
    well I was able to track it down from smell last night, not sure, but from looking in chilton book, its called "hot fuel module" it looks like a small circuit board . I can remove the small module and the truck starts/stops like normal, but I think if the truck sat for a while it wouldnt have the fuel presure to start. Now my only worry is that theres a short somewhere elese that cause this to fail?
    So I did some searching, and find little info on hot fuel module, maybe its not needed? is it a emmisions thing? cant find replacment.
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    Oh **** um try the.... **** it's fuel injected um unplug the distributor module
  3. gonger
    Nov 8, 2004
    42
    okk, I pulled the ecm fuse and got to shut down, but what the f@#.!!!
  4. yellowK20
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    I'm not much help On the fuelie trucks never had to work on them it may be your column is it a tilt ??? sometimes if the column is real loose and sloppy it makes it to where the switch doesn't get it's full range of motion
  5. yellowK20
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    the igniton switch is located on the top of steering column near the floor with a rod that runs up to the tumbler sometimes the switch can go bad or the rod could bindup/break/come loose
  6. tRustyK5
    Jul 23, 2000
    36,169
    1,366
    E-town baby!
    I'll second the iggy switch. 20 minute job to replace...
    Our 88XJ used a GM column and I replaced the iggy switch in that about 6 times before getting rid of it.
    Rene
  7. gonger
    Nov 8, 2004
    42
  8. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    That kind of thing has usually been a result of a bad ignition switch for me (on several make and models of vehicles).
