QUICK HELP!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stimpy, Dec 3, 2000.
  1. stimpy
    stimpy Registered Member
    Aug 31, 2000
    74
    Lake Tahoe, CA
    I can't get the pinnon shaft out!!!! I took out the retaining bolt but the shaft won't slide out. I even tried hitting it out. Any ideas guys. I have dinner guest comming over and want to get this done before dark.
    Todd Miller
    love my blazer, and 43 Dodge Carryall
    IF IT'S SNOWING AND IT'S DEEP. I'LL BE OUT IN IT!!!!!!
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Need more info dude! What kind of diff? What have you done so far?
    Rene
  3. stimpy
    Aug 31, 2000
    74
    Lake Tahoe, CA
    OOPPS!!! Sorry,
    I have a 84 Blazer with the stock 10 bolt. I'm trying to replace the seals and bearrings on the axles. I can't get the one shaft out to get the C-clips off. Hope that's enough info.
    Todd Miller
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    So you're trying to remove the 'pinion shaft'? My manual says there should be a retaining screw that needs to be removed. If you've done that the pinion shaft should pretty well slide out. I recall on my old S-10 that the retaining bolt was in pretty tight, so I used a six-point socket on it to prevent rounding off the corners.
    Sorry just re-read your first post and saw you already removed the retaining screw. Try rotating the diff and gently tapping on each end of the pinion shaft. Use a socket that is slightly smaller than the pinion shaft as a 'drift'.
    Rene
  5. stimpy
    Aug 31, 2000
    74
    Lake Tahoe, CA
    Hey Rene,
    I've taking out the bolt. The shaft has a little give but it wont slide out, it seems to get caught on something, and I move the hub so the saft has room to slide out on both sides but no luck. Like I said I've even tried banging it out with no luck.
    Todd Miller
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    You might have a little 'step' in the pinion shaft. Can you rotate it? If it rotates try and rotate it a little and see if it moves up and down some. The manual says to be careful it doesn't fall out! You should have that problem huh!
    Rene
  7. stimpy
    Aug 31, 2000
    74
    Lake Tahoe, CA
    Thanks Rene,
    I'll go back out to my shop right now and tinler some more. I'll let you know if this worked.
    Thanks,
    Todd Miller
  8. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Good luck!
    Rene
