QUICK!!! How do I get the turn signal lever out??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Nov 11, 2001.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    Salem ,Or
    I'm rebuilding my column and I can't figure out the turn signal lever. How do I pull it out??? Or do I need to.
    Displacement, cubes, and did you say you drive a riceburner???
  2. do you mean the lever itself or the plastic switch it's screwed to? if it's the switch then you have to take the wheel and lock plate off, disconect the wire harness for the switch and pull it up through the column. kinda a pain in ars. it helps to unbolt the column from the dash so its easier to fish the wire harness out. hope this helps
    <font color=blue> Experience enables you to recognize a mistake when you make it again.
    </font color=blue>
