Quick HP Gains and Tires And FLOODING
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82Jimmy, Mar 29, 2001.
  1. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    Hey Guys..long time no words...I'm getting back into the JIMMY! I frickin found out what was wrong with it. The SOB was only firing on 5 cylinders.....(not good) Also after I did all this, got the timing right and it was running "well" it started loading up and puttin around like it had never had so much gas before. Pisses me off...........................anyone know what I could do to fix it? It has a mild cam and a 650cfm Carb...
    ..........and one time at band camp.........
  2. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    You did change the plugs/wire/cap/rotor, didn't you? You might want to adjust the carb a little or check the fuel filter and pump to make sure that there aren't any malfunctions there.
    [​IMG]<A target="_blank" HREF=http://www4.ncsu.edu/~brschoch>http://www4.ncsu.edu/~brschoch</A>
    My truck beat up your SUV
  3. 82Jimmy
    Jun 9, 2000
    702
    I did all that, weird crap here. Gas is in it about 2 inches over full.........i guess i gotta go empty it and spend $20 on oil (again)
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    You say gas is in it? In the oil??? Have you check your fuel pump? A friend of mine had a bad diaphram inhis once and it was literally filling the engine with gas... We pulled the plugs and it shot out the holes like a firehose!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    I also forgot to mention, Welcome back!!!
    Mike [​IMG]
