Quick Hydroboost question
Discussion in 'The Garage' started by Flamin' Fast, Mar 21, 2007.
  1. Flamin' Fast
    Flamin' Fast Registered Member
    Jul 21, 2005
    75
    Bountiful, UT
    i just converted to hydroboost brakes and now i dont have power brakes or power steering at an idle. i just used the pump that i had on the 350. would using the diesel pump fix my problems?
  2. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    your gonna need the hydroboost pump. It makes way more pressure than the one you've got.
  3. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Thje pumps should all be the same(housing would differ not internals). You might try bleeding your system again. Sometimes it won't whine at idle when very low, then when you add more to it it starts to whine and that is when you normally get the bubbles. Keep turning the wheel lock to lock until the bubbles are gone and keep adding fluid till full.
  4. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    hmm, count me mistaken.
  5. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    if 2 hose system 2 hose pump needed. if 3 hose system then 3 hose pump needed.
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The pumps are the same. If you look up the part numbers for just the pump without the rez they will be the same. I have a regular pump on my HB unit with Hydro Assist and it works fine. I would suggest you bleed the system again. With HB you need to bleed the steering as you normally would but you need to press the brake pedal alternatly while turning the wheel left and right. The only way to ensure you get all of the air out of the HB unit is by pressing the brake peddle.
    Ira
  7. johnnychimpo
    Oct 9, 2005
    1,145
    Nash, TN
    No! count me mistaken.
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    How did you plumb the return line from the hydro boost unit?
    The resevior with the extra fitting (or braze and extra fitting into your resevoir) seems to work much better than tee-ing into the existing PS return line. Must be a volume thing,but that is the experience a few have had here.
  9. Flamin' Fast
    Jul 21, 2005
    75
    Bountiful, UT
    ya. i just Tee'd the two return lines together. i never thought about pushing the brake when bleeding the system. i will try that today. expect pictures of my build to be posted soon!
  10. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Note that while the tee fitting scares people including me, at the least, consider the directions it's tee'd in. I found these on a web page somewhere...
    -- A
  11. Flamin' Fast
    Jul 21, 2005
    75
    Bountiful, UT
    i have the T installed just like the bottom picture. right now it seems like ther is no power steering and no power brakes no matter what RPM the engine is running at. so i dont know if bleeding the system will help or not
  12. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I had mine tee'd at one point and it seemed to work just well enough.
    The only thing I noticed is lag when turning the wheel while stopped. Don't notice that with an pump that was listed for hydroboost and has the 2 separate return line ports.
    I recently drained the system to do crossover and you have to keep checking the level a lot before it's finally full.
  13. Flamin' Fast
    Jul 21, 2005
    75
    Bountiful, UT
    i tried bleeding the system at lunch today with no luck. i think i might have a bad pump. it doesnt seem like it is helping at all now. i have two pumps just sitting in the garage, i will probably try to swap one of those in tonight.
  14. Flamin' Fast
    Jul 21, 2005
    75
    Bountiful, UT
    everything was working good after i swapped the pump, i had power steering and power brakes! but then after driving for a few miles the pump started to push the fluid out of the cap to the power steering resivoir, and now i have no power assist. what would cause the pump to do this?
  15. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    While looking for a hydroboost pump at the JY, I ran across a few diesel factory application where they teed the return line.
  16. dremu
    Feb 27, 2000
    15,958
    452
    Overheating (PS fluid) is the first thing that comes to mind. Is it white and foamy?
    -- A
  17. sandawgk5
    Oct 28, 2003
    6,881
    A large air bubble will do it also as the air will expand faster than the fluid will when it warms up. The air will get trapped and push fluid out of the rez. I would still check level and do the bleed procedure. Sometimes it can take hours to get all of the air out.
    Ira
