quick ignition question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big pappa b, Sep 21, 2003.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    On an electronic ignition distributor, isn't the #1 plug just to right of the plug in for the battery/tach plugs?
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    do you mean HEI? if so, if you were to look down at the dist. from the front of the engine, I believe that #1 should just about be at the 4-5 o'clock position.
    rick
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    No 1 can be put anywhere on the cap as long as the rest of the order follows.
    Something you really should verify yourself....
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It SHOULD be the next one clockwise after the plugins. That's where the factory puts it s that's where I always put it.
  5. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I second that. It doesn't matter where you put it as long as you follow 1-8-4-3-6-5-7-2. /forums/images/graemlins/grin.gif
    -Dan
  6. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I just asked that way cuz that's the way I always did it. When I dropped the distributor in I thought I may have had it in 180 out or maybe a plug wire in the wrong spot but it turned out to be that I had it retarded a bit too much /forums/images/graemlins/tongue.gif
    All is good in BIG BLOCK-ville
