Quick Kingpin Help?
Discussion in 'The Garage' started by mtnman210, Apr 8, 2006.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I had some time today so I decided to try my hand at rebuilding the kingpins on the new dana 60. This is my first time dealing with them but I've been following [FONT=Arial, Helvetica, sans-serif]BillaVista's manual and it's been fairly easy. I've got one side completely done and used eveything in the box except the tall seal which it says is used in older Fords, BUT I also have 4 nuts left over(they were sealed together). I've looked through the manual and looked on the axle and can't figure out what they're for. Are they for Ford's as well or did I miss something?
    [/FONT]
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    What size are the nuts? If they are like 1/2" or so and look like wheel lug nuts then those are for the driver side steering arm. The other side would have bolts holding the king pin cap down.
  3. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    the steering arm would make sense. I didn't even think of it because I don't have a steering arm for either side. I'll snap a quick picture in the morning of what it looks like and what the nuts look like.
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Just go see if the nuts fit the studs on the driver side knuckle. The nut will look like a lug nut with a taper on one side which fits the taper on the steering arm.
  5. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I just rebuilt the king pins in my 60 last weekend and the only place that these could go (from your description) is the steering arm king pin plate.
