Quick less common 14 bolt question
Discussion in 'The Garage' started by sled_dog, Dec 25, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'm forseeing the K5 being 4 link front and rear by this time next year. If i get another 14 bolt and strip it down to just the housing will the carrier and pinion assembly from my present 14 bolt swap over just fine? No need for gear setting and such? Figure working on a bare housing that won't be used for a while will be simpler than working on what I have.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    You can swap them, but they will need to be reset....
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah you wil need tools that us redneck backyard mechanics dont have, in order to set you pinion depth and gear tooth pattern and so forth, you just dont thorw in carrier and gears and go, you have to set it all up juuuuuuuust right or disaster happens
    is cheaper and easier to just take and swap in entire axle with ratio you want,
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah well I'm not sure whats gonna happen with gearing right now but I know a shop that can help me out on that one.
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    All you have to do is get the pinion depth and backlash set up like the old axle. Both are easy to set on a 10 1/2" 14 bolt because of the design of the axle. Just check the backlash and run a pattern on your old axle before you pull the gears out. Then start with the same pinion depth shims and set the backlash the same in the new housing. Run a pattern, and if it is close to what you had in the old housing, you are good to go. Otherwise play with the pinion depth (add/remove shims) to match the old pattern.
