QUICK!!! need info on Echobit shackle flip
Discussion in 'The Garage' started by bigbadchev84, Sep 29, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i am planning on doing my shackle flip tonight and need to know what size pieces of metal i need and what thickness....i did a search and couldnt find the actual measurements, other than how and where to drill the holes, would 3/8" be ok or should i go with 1/2" also i am needing to lengthen the front shackles on the rear of the front spring, there are going to be 2x12" long, would 3/8 bo ok here or 1/2"???? thanks guys i need this info quick! i will be ordering the stuff from the shop before i leave work today! thanks guys
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I don't know about the sizes etc, but I just measured mine and they are 1/4" thick. Hope this somewhat helps.
  3. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    From a search... Hope it helps
  4. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    999
    593
    Pueblo, CO
    Did I read that correctly? a 12" front shackle? please say thats a typo. first of all you only get 1/2 of the length of the shackle for any lift. Plus your caster is going to be off big time on the front axle.
    A 12" shackle up front is a bad idea. Like blocks up front are a bad idea.
  5. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    nope not a typo, i have custom spring hangers on the front that dropped the hangers 6 inches more than stock, i never did the back and still have the factory hangers out back and the caster is WAYYYYY off right now.....there is no return to center when i am cruising at slow speeds.....very scary. factory holes a 3-3/4 on center +6"+another 1" on both ends is 11-3/4 shackle.link to my other pics
  6. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Thats alot (twice) of leverage on your shackle mount! You better upgrade bolts and watch your bushings closely... might also need a panhard bar.
