quick one...vent tube vs fill plug?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77Jimmy, Jun 24, 2003.
  1. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    Yes, I'm asking yet ANOTHER lamo question...on a 12b rear diff, the fill plug is the recessed square plug correct? What is the purpose of the tube that comes out of the top of the differential? My tube runs up out the top of the diff (on the same side as the fill plug but above the fill plug) and is bolted w/ a small bracket to the frame w/ a plug at the top of the tube.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    vent tube lets pressure out (air)
  3. 77Jimmy
    Sep 3, 2002
    661
    Atlanta, GA
    Ok, thanks. /forums/images/graemlins/thumb.gif
    I need to check out that plug at the end of the vent tube and see how it works...am curious.
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Just ran longer vent tubes into the engine compartment today. Used a K&N crankcase breather /forums/images/graemlins/thumb.gif
    Shorter tubes can allow water to get in.
    Has anyone noticed gear oil build up in the tubes where it runs along the frame rail from the rear? I wonder how it breathes then....?
    I noticed a bit of fluid from my front where there was a low hanging part of the hose. I will probably check/drain those low points periodically.
    Sorry for the hi-jack /forums/images/graemlins/grin.gif
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    It's just a mushroom vent. The best engineered ones out there in my opinion. Aftermarket places make the ones with a bunch of little holes but they're like $6. Other manufacturers use all sorts of weird things including stone filters (like fish tank air bubbler things) and merely a piece of foam on a fitting you plug into the hose.
  6. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Well, you're not supposed to have sagging lines. If you route your rear vent tube up inbetween the inner and outer bed skins then you don't have to run it out front and therefore don't have sags. For the transmission and transfer case you merely route it up along with the speedometer cable and terminate them by the brake booster.
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I'll look at re-routing..... I followed the frame rail and that put a BIG dip in it.
    Thanks for the suggestion /forums/images/graemlins/grin.gif
