Quick Ques - 10 bolt to D44 swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBurban350, Dec 16, 2002.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I am swapping my front axle out of my 90' Burban, a 10-bolt is there now and im putting in a D44 to match my 14FF in the rear that I have recently installed. I was wondering if the steering linkage will bolt up, and if the u-joints will bolt up for the front drive shaft. Thanks. /forums/images/graemlins/burb.gif
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">All that will bolt up but the brake lines are different
  3. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Do you know the remedy for the front brake lines? Would I have to order front brake lines from say an 84' 3/4 Suburban(where the axles came from)? /forums/images/graemlins/burb.gif
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Yes, you can buy them from any parts store in stock length.
    If you have much of a lift, you will need longer one for flex. Procomp sells them.
    I have a used set for sale from when I changed over to a D60.
    -- Mike
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Additional question: What about just putting the 10 bolt calipers on the 44? Will they fit/work on the 3/4 ton 44? If they do, that should get rid of the brake line problem. /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  6. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I think that will work.
    If I remember correctly, I used my D44 calipers on my 10 bolt, so it would go the other way too.
    I think he'll need longer lines than stockers though, if he wheels much.
    -- Mike
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Just leave the 10-bolt calipers in place and then use them on the 44. The only difference is that the 10-bolt calipers have a metric thread. They'll fit the 44 bracket just fine and you won't even have to bleed the brakes. /forums/images/graemlins/cool.gif
  8. heavy4x4
    Aug 28, 2002
    3,270
    Sweet. That's what I was thinking/hoping /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    The u-bolts are different also.
  10. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    your driveshaft will bolt right up. You can used the 10 bolt calipers (I would so you don't have to bleed the brakes). The only difference as far as swapping is concerned is that 10 bolts use metric banjo bolts and 44's use standard....10mm and 7/16 respecively.
