Quick Ques. 305, 350, 400
Discussion in 'The Garage' started by BigBurban350, Jan 9, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Are the crank journals all the same size in 305, 350, and 400 small blocks? /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    305s and 350s have the same main journal diameter of 2.45". 400 cid engines have 2.65" dia. main journals. Most 327s and all older SBs had 2.3" dia. main journals.
  3. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    327's past 69?????I THINK /forums/images/graemlins/truck.gif had the same size mains as 350's and 305 's and 307's
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The 327's went through a change sometime. the newer ones had the same size bearings. dont remember when they changed though.
  5. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Arnen't 400s externally balanced as well?
  6. BigBurban350
    Jun 9, 2002
    711
    Michigan
    So do stroker kits (383/388) have a specially made crank with 350 journals, or do you got to bore the journals?
  7. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    They most certainly are! /forums/images/graemlins/grin.gif As well as the 454. I ran a 400 for many years and then switched to a 454. I used the same flywheel. You cant use the same harmonic balancer though.
  8. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    The stroker cranks will have the main journal size of the 350, but the stroke of a 400.
  9. Blazer1970
    1,600
    Old Mission, MI
    Or you can use a 400 crank, and have the main journals turned down to the smaller dimension. This is how the idea of the 383 originated.
  10. bigmack
    Jan 3, 2002
    478
    Tennessee
    Yep, you sure can. That is what alot people do. If you allready have a 400 crank, it would be cheaper to have the mains turned down than to buy a whole new crank.
