quick question about moving my front axel forward..
Discussion in 'The Garage' started by supersize75, Nov 16, 2003.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    OK
    What are the pro's / con's?
    I alread have the zero rates with the option on them but currently have it installed in the stock location. My tires dont hit curently "38's" and I think I can thank the 3 inch body lift /forums/images/graemlins/thumb.gif
    I have all my stuff for cross over and ready to get it on the truck, just pondering on the axel location /forums/images/graemlins/thinking.gif
    I run a reciever style front bumper, and just wondering how much this will help with my approach angle?
  2. supersize75
    Sep 27, 2002
    2,638
    also hydro assist is in line for next month, I was also wondering about interfearence with anything if I moved it forward??
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    drive shaft may have to be altered. If you go with just the 1" or 1.5" that the offset blocks provide I don't see any serious problems. Drag link may interfere with leaf spring on the passenger side. I think it depends on your spring pack thickness, amount of lift, what your using for an arm and other variables.
  4. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    If you have histeer, or are planning to use it....things get tight on the D.S. (Steering arm to tie rod clearance)
    There's a post in the ORD forum if you want more details.
  5. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    I agree, my axle is move forward 1.5" and after pondering the normal Hi-steer for a while , I came to the conclusion that only the behind the axle hi-steer would work for me.
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have my front axel moved faward 1". With the "conservative" lift of 9+3, the 44's hit the firewall under full flex. The 1" gave me Just a little xtra clearance. I have just the "normal" crossover and don't seem to hit.
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    My axle is forward 1.75" from stock. My crossover works fine and it gave me enough clearance that I'm dropping the body lift down from 3" to 1".
    This is 6" lift with a 3" body lift and the axle forward.
