Quick question before running to the parts store
Discussion in 'The Garage' started by SS66, Jun 12, 2005.
  1. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    What type of grease should I use for poly leaf spring bushings?
  2. Storm Trooper
    Nov 24, 2000
    4,640
    (IMO) If you don't have greaseable bolts, I'd recommend that you use the silicone dielectric grease. It won't break-down the ploy.
  3. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    I use marine grease will that break down the poly? Sorry for the hi jack on your thread SS66.
  4. dyeager535
    26,980
    Poly is supposed to be resistant to oil, I would *think* petroleum based grease of any kind would therefore be ok...curious to hear otherwise though! :)
  5. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    I would think that if most grese is labled wheelbering and chasis lube then it should be alright. I would think that grese would rot rubber before poly but I could be wrong.
  6. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    (IMO) If you don't have greaseable bolts, I'd recommend that you use the silicone dielectric grease. It won't break-down the ploy.)
    I have to agree with Storm Tropper, thats what i use- but im partial to synthetics
  7. Storm Trooper
    Nov 24, 2000
    4,640
    Under normal conditions regular grease would be fine but if you flex your truck out like I do, after time, the reg. grease will soften the bushings and I have found that they crack so I just use the best. It's up to you and opinions will very from everyone.
