Quick Question code 32 only setts check engine light on when...
Discussion in 'The Garage' started by foxman, Dec 4, 2003.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    This happens on the express way when I'm on long trips. Truck seems a little more sluggish than before since the code appeared. It resets after I shut engine off and comes on only at higher speeds over time. Happened to my 90 blazer as well never found the problem.. This has to be a common thing if I had 2 blazers do tha same thing???
    What is the problem with it..??? /forums/images/graemlins/confused.gif
    (88 stock 350 tbi)
    Jeremy
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Code 32 is the EGR valve. Might want to give that a looksee. /forums/images/graemlins/thumb.gif
