QUick Question "hood latch"
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by drchan, Mar 15, 2003.
  1. drchan
    drchan Registered Member
    Sep 4, 2002
    74
    edmond, oklahoma
    QUick Question \"hood latch\"
    I have a 72 k5. i changed the hood hinges today and i can't get the lacth to open the hood. it dind't open the hood before i changed the hinges either (i would pull the latch and have to push on the hood real hard but now i can't even do that, but when i looked at the latch everything appears to work, on the latch" and old body shop guy told me that there shold be a spring that pops the hood up. i've never seen a spring attached under the hood on a 72. my question is, is there supposed to be a spring near or around the ball that goes into the latch when you close the hood or not. i hope someone is understanding what i'm trying to ask. if there is no spring then maybe everything isn't lined up perfect. the hood looks like it is sitting in the proper position. i tried to adjust that little ball under the hood but that dind't work. any advice would be appreciated. ok maybe it wasn't a quick question, sorry /forums/images/graemlins/confused.gif can someone look and see if they have a big spring located under the hood anywhere
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Re: QUick Question \"hood latch\"
    latch assembly is probably junk or needs soaked in atf or something, spray the heck out of it with PB Blaster from NAPA, etc
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    There is no helper spring on the Blazer. You need to readjust the thing so it properly aligns with the catch on the hood and lubricate it and the hinges properly.
  4. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
  5. drchan
    Sep 4, 2002
    74
    edmond, oklahoma
    thanks i'll try you suggestions
