Quick question: How much do i tighten the spindle nuts on a 14 FF?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Silverado4x4, Apr 13, 2001.
  1. Silverado4x4
    Silverado4x4 Registered Member
    Oct 2, 2000
    61
    Illinios, southwest of chicago
    Theirs those two circle nuts that go on after the drum, how much do i tighten them? thanks
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Tighten them until theres just a slight amount of drag (but not too much) then tighten it 1/8 turn more. </font color=blue>
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Do exactly like Biggray says .......... tighten till it's tight, then go clockwise until a keyhole lines up.
    I did mine about a MILLION times trying to fix a freakin' axle seal leak, and one thing I found out was that it is a good idea to smack the drum inward with the palms of your hands a few times while tightening it. If you hear/feel the drum move in/out at all, then keep tightening until it's all the way in.
    I know it seems obvious, but a few times when I went to take them back off, it was loose ....... so I guess I didn't tighten it all the way the first time even though it seemed pretty tight.
    Thomas.
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
  4. Silverado4x4
    Oct 2, 2000
    61
    like tight like "tight" or just snug?
  5. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    I used a punch/pry bar and a hammer to tighten it all the way, so I guess I would say tight tight.
    But then again, my threads could be in worse shape than yours are, so I would just tighten it up until there is no more play in the drum when you smack it, then go clockwise with it until a key hole lines up.
    Thomas.
    -- '84 K5 Blazer --
