Quick question on coolant/freezing
Discussion in 'The Garage' started by FMJ, Apr 25, 2005.
  1. FMJ
    FMJ Registered Member
    Dec 29, 2004
    94
    Duluth, MN
    I filled my 440 with water to run it for the first time becuase i knew it would spill all over and i didn't want to have to deal with anti-freeze. SO anyway it's going to get down to 32 tonight, and even though i took the plugs out of both sides im still worriued that somthing might happen? I've been having some bad luck with this thing and i really don't need to lose it all because of this. Should I add anti-freeze, or will it be ok?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You should be ok but just leave the radiator cap off.
  3. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    you could blow some air around in there and you might get some water out. i think youll be fine though.
  4. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    dont forget the heater core needs draining. and if pulled block drains it should be o.k.
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Just minimize the amount of water in it and leave all the available ports and plugs open. The water freezing isn't what kills you, it's the fact that it expands in the process. If you get most of the water out you should be fine.
