Quick question on intake gasket.
Discussion in 'The Garage' started by FMJ, Jan 4, 2005.
  1. FMJ
    FMJ Registered Member
    Dec 29, 2004
    94
    Duluth, MN
    Should I put silicon around every intake hole on both sides of the gasket, and should I do the water passage too? The gasket i'm using is metal, and it is going on my 440. Thanks for any help.
  2. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Valley pan style??
    If its the kind that looks like a turkey basting pan made of metal,I would use a little bead of silicone around all the ports--just dont use too much,any excess will likely get itno the motor and cause problems..I ofen use some RTV on small block chevy intake gaskets,even though Fel-Pro says not too--sometimes the heads have been planed,or the block decked,and ports dont always sit perfectly flush,and the gasket isnt thick enough to take up the gap,and you end up with an internal vacuum leak that can suck oil out of the lifter gallery...:crazy:
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    personally i would have went with fel pro, blue ones, common, they self seal, are cheap too, all would have had to do was RTV front and rear ends of intake and corners and have been done
    i really dont know why anyone would use anything else
    have installed so damn many fel pro intake and head gaskets i will never be able to count, fixed a freakign ton of old chevies up in no time and for good
    impossible to count so many
    good luck
