quick question on shimming
Discussion in 'The Garage' started by supersize75k5, Feb 24, 2004.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I did the drop through the hanger shackle flip, then decided to use a 4 degree shim sooo
    just to double check..
    I want the thick part of the ship at the rear correct? pointy end at the front???
    also do stock springs have a drection front/back to them just double checking everything for the 83 /forums/images/graemlins/ears.gif
    /forums/images/graemlins/waytogo.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    You are correct on the shims.
    As far as the springs, I have no idea /forums/images/graemlins/dunno.gif
  3. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    It depends on what your trying to do. /forums/images/graemlins/dunno.gif Are you running a CV shaft and trying to point the pinion at the back of the t-case. Then the thick side of the shim needs to point towards the back of the truck.
    If your trying to correct the pinion angle from the shackle flip and still using the stock non-cv driveshaft. Then the pinion needs to rotate down and the thick side of the shim needs to point forward. /forums/images/graemlins/peace.gif
    Mike
  4. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    I went from a 10bolt/4" spring to a 14bolt/shackle flip5.5" w/ stock springs. I used a 5degree shim to bring the pinion angle down closer towords horizontal. The shackle flip actually shot my pinion over the tcase prior to shimming. thick part facing front for me.
    ~Jason
