Quick question
Discussion in 'The Garage' started by 1BadK-30, Mar 8, 2007.
  1. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    Whats the fuse labled Horn dm on the fusebox for? I know its for the horn but whats the DM part for?
  2. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    Dome.... Gm liked to break up functions and run them on various circuits to give some redundancy.. Thus why your light functions have been broken into 4 or so different fused circuits, coutesy lights, stop, etc...
  3. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    Interesting part on GM, like I said in your pm thank you very much.
  4. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    cig lighter too...
  5. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    That would explain why its not working, I have 2 cig lighters would I be able to get away with plugging 2 into it sense 1 currently isn't pluged in?
  6. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    they should be already routed into this fuse panel if they're stock...
  7. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    1 is the other isn't.
  8. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    for the one that is, check the grounds which is literaly the casingfor the entire assy...make sure theres no random wire jsut hangin back there...mine was like this, the pwoer wire got cut and kept shorting out the circuit. never could figure it out till i pulled the whole cig lighter assy out on purpose. LOL
  9. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    oh and to make sure its workin get a tset light or volt meter. adn put the pos in teh VERY center of the shaft on the brass pin in the bottom. ground other obviously.
  10. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    Ok will do, thanks abunch.
  11. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    no prob i fought that **** for a while too. lol
