Quick Question
Discussion in 'The Garage' started by RatMan, Dec 19, 2002.
  1. RatMan
    RatMan 1/2 ton status
    Jul 27, 2002
    270
    Marietta, Georgia
    if i put in a higher output alternator, do i have to change any of my other electical things? i went to the store to get a new one today, but fergot my cash /forums/images/graemlins/rolleyes.gif never made it back over, but i got to thinking abou this TIA!
  2. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    i think you need a bigger power feed wire from the alt. to the battery, i think most places suggest a 4 gauge wire. hope this helps
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    If I recall correctly, a stock alternator is 45-55 amps. I dropped a 90 amp in my truck without any additional modifications, and I think you can run to a 120 amp safely. Your 89 is 10 years newer than mine, you should be able to run at least a 90 amp safely.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Bad Bo Ti is correct, you need to change the feed wire to a 4 gauge cable. You don't want any electrical fires because of too small a wire trying to do a much harder job do you? It is cheap insurance anyhow.
