Quick question
Discussion in 'The Garage' started by muddin4fun, Feb 1, 2003.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Can you test your alternator with an ohm's to see how much it's putting out while running on the vehical?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    you can test it with an amp meter or a quick check with a volt meter. If you are showing more than 12.4 volts, it's working. But an amp meter will tell you if it's charging to full capability. You can test the diodes with a ohm meter, but it must be a digital style.
  3. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    No, you will ruin an ohm meter if you power to it. Unless it is one of the high end ones like a Fluke 87 that should prevent you from destroying it. It still won't read ohms, but you won't need to buy an new meter.
    Like ba said you need to use a volt meter or an ameter.
  4. Grim-Reaper
    7,385
    Atlanta
    Moat parts stores will test them for free. If the truck is running they can proably test it on the truck.
