Quick Question
Discussion in 'The Garage' started by TONYP, Feb 17, 2003.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I need to know what the center hole is in a 8 lug rim (or the hub dia.) Should be around 4-3/8"...Thanks /forums/images/graemlins/ears.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Gee, I wonder why'd you need to know that - lol
    I measured my 14 bolt hub itself and it looks like a 4 3/8" is the measurement of the OD of the hub.
    IF a wheel spacer were meade to that measurement, it would show through AROUND the hub because the hole for the wheel is bigger than that.
    If you give me about 30 minutes i'll go take a wheel off and meaure mine.
    -- Mike
  3. TONYP
    Aug 13, 2002
    2,116
    so cal
    you got it, I'm the only one here today as it's a day off for us...but I'm taking friday off so I switched days...
  4. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I measured the hole in my wheels.
    Wheels are 15x10 8 lug Rock Cralwers (from 4WPW) that I bought a couple years ago.
    They measured right at 5-1/8 (5.125) inches.
    If the hole for the spacer needs to be a little smaller than that for strength, I don't see why 5" wouldn't work. It would only show a little. And of course 5-1/8" would be flush for my wheels but everyone's are a little different I think.
    -- Mike
  5. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    Aftermarket wheels have a larger center hole. I found this out after I had my dually hubs machined. I believe chevy factory wheels are the smallest of the big 3. I do know that ford wheels have a larger hole (though not as large as the aftermarket wheels that I have checked), don't know what dodge is. The best thing to do would be to find the wheels you want to use and measure them.
    Brett /forums/images/graemlins/burb.gif77 /forums/images/graemlins/k5.gif74
  6. TONYP
    Aug 13, 2002
    2,116
    so cal
    I'm going to use the 5-1/8" for the center...the lug holes are drillinf and reaming right now..
  7. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Are you by chance making a 8 to 6 lug adaptor that requires no machining of the hubs?
  8. TONYP
    Aug 13, 2002
    2,116
    so cal
    if you don't machine the hub then you would have to open the center hole in your rim, if you can do that then you would not have to cut your hubs...
