Quick Questions
Discussion in 'The Garage' started by nstarry, Mar 18, 2007.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    Hey thanks for the response in advance!!!
    Question ?I just found a budy with a wrecker 89 ish (throtle bodied chevy),front dana 60, turbo 400 ,t-case is a questoin as of yet. I can get the tranny t-case, 52 inch springs, and 60 all working good for 1000.00 pulled !!:laugh::p::eek: what do I need to convert the 60 to single wheel and will the speed sensor stuff all work on my 93 blazer 4x4 350 throtle body
  2. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    Okay I am not an idiot trying to get sombody to tell me how to do it!!
    I was just trying to keep it short and sweet, I know that the knuckles need to be swapped, and that you can use the old spindles can you use the same axel shafts is there anything hidden ( :bow:I have never touched a dana 60 :bow:) ??? did they run 208 in the one tons, or 241s, or ?( I cant get out there to look hes going to pull everything and drop at my house ) will my newer vss sensor be the same as the old style ( or is it different at all )?? or should I tell him forget the t-case and look for another?
  3. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    that truck should have 56" rear springs on it. might be a slip yoke np205 t-case. to convert the 60, all you need are the single wheel hubs and rotors. i have no idea about the speed sensors, altho those 2 trucks are different generations, so i would imagine they would be differerent.
  4. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    he has a different set of 52'' s that are off a half ton he is throughing in .
    so the knuckles have nothing to do with it its just the hubs and rotors , that sweetins the deal alot thanks man:bow::D:D:D:D:D:D
