Quick,Quick,Quick!!!
Discussion in 'The Garage' started by wasted wages, Jan 12, 2005.
  1. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    What backspacing should I use for a D60 and 14 bolt ???
    I want to order my wheels today and am unsure what
    backspacing I need on MRT's bead locks,,15x12's
    What does everyone here run?????
  2. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,268
    159
    Wisconsin
    I believe I have 4.75" on 16.5" x 10" wheels with 36 x 14.5" swampers.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I think 4.5" is pretty common number. Less backspacing = less grinding on the calipers but you have probably already been through that.
  4. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I am running 3 1/2" BS on my 15x12 beadlocks, but 3/4 ton. Have a good 5 or so inches out from the fender with 17x40 Hawgs. Not sure if this helped or not.
  5. wasted wages
    Dec 3, 2003
    9,194
    Dallas Texas
    My main concern is the rotor/caliper clearance,,,
    I have already ground down the calipers for the 15x10's.
    will a 15x12 mean more grinding or is the backspacing
    what causes the calipers to need clearance,,,MRT only
    lists up to 4" backspace on their beadlocks,,my 15x10's have 4 1/2"
    will a 4" give me more or less room at the caliper ???
    Confused,,,,
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The lower the number the less you need to grind. The bigger the number the more you need to grind.
    You need to grind more for a 4" BS rim to fit then a 3" BS rim.
    Harley
