Quick ratio steering box?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mcmlxix, Apr 30, 2003.
  1. mcmlxix
    mcmlxix Registered Member
    Nov 28, 2001
    80
    Las Vegas
    My box is leaking so I want to know if there is a quick ratio power steering box. I have a 70 K5 with manual drums that I want to put an 88 K5 disc rear in front. (if it makes a difference)
  2. mcmlxix
    Nov 28, 2001
    80
    Las Vegas
    I did a search ... nothing on quick ratio ... I know they have an option for camaros and chevelles. Any one hear about it for first gen k5 w/ power steering?
    Anyone who has swapped a newer motor, can I use the stock PS pump with the 88 TBI 350 that I am swapping in with my existing PS box? Will the hoses mate up?
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    PM TheLakeRat and ask him about the quick ratio. I have no idea.
    I don't know if a newer pump will bolt up to your mounts because of the difference between short and long water pumps but I suspect it will.
    The newer pumps and steering boxes have o-ring fittings insted of the old flare fittings that are on our trucks. You will have to put your old pressure regulator in the new pump.
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    maybe I"m looking at this wrong but a rear axle will not work in the front.
  5. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    A company called AGR makes 2 different boxes for are trucks. 1 is the stock ratio, the other is modified for easy turning at slow speed. I am not sure of the details. I have the stock replacment AGR on my GMC. It feels great and has been hanging there for a year with no leaks yet.
  6. mcmlxix
    Nov 28, 2001
    80
    Las Vegas
    Sorry. /forums/images/graemlins/eek.gif Axle to me means a part of the rear. When I say "rear" I an used to meaning the complete assembly. If I was more specific I probably would have said front rear or rear rear. I guess if I analize it it sounds like an oxymoron.
