Quick Release Door Hinge Ideas
Discussion in 'The Garage' started by nvrenuf, Feb 13, 2004.
  1. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I'm thinking of doing some half doors in the future so I'm interested in doing quick release door hinges. Has anybody done anything like this? I want to leave the hinge halves attached to the body and door to retain good alignment.
    BTW - I searched for both "door hinge" & "quick release door hinge" but the list is endless without ever really covering this subject.
  2. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    you could do something like a jeep wrangler door.
  3. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I had thought about that but I'm really curious to see if anyone has done anything with quick release pins. /forums/images/graemlins/thinking.gif
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    its been done....dont ya just love the search feature, i can never get the info
    i'm lookin for... /forums/images/graemlins/dunno.gif /forums/images/graemlins/waytogo.gif
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Well now, this is funny. You see, I made that particular mordification to my door about a year ago. I could pull my doors in less than 2 minutes and be driving down the road. Here are the bennefits and the cons.
    Benefits - Cool, cheap, and easy mod to do. Plus you can get your doors off in a hurry. /forums/images/graemlins/waytogo.gif
    Cons - If you don't do it right, your door will fall off in a parking lot like mine did! /forums/images/graemlins/angryfire.gif I caught it, but the door almost hit the ground and had some serious damage to it.
    Parts you need;
    1. New hinge bushings
    2. 2 feet of 3/8" dia. steel rod or longer hing pins but with the same dia. and flared head (That is what I used).
    3. 3/8" washers
    4. 4 cotter pins
    5. Sumthin' ta drink
    6. Tunage to listen to
    How to do it;
    1. Turn on yer favorite tunes.
    2. Open yer drink and take a good long pull.
    3. Mark your doors and hinges with aligment marks.
    4. Measure how much room you have on the top and bottom of your door hinges (this is critical!!)
    5. Unbolt your doors and set them aside.
    6. Take out your old pins and bushings (remember how the bushings go it).
    7. Cut your rod or longer pins to the correct length and drill a hole in them big enough for the cotterpins to go through. Remember to cut the rod/pins long enough so that you can slip the washer over the rod/pin and still get the cotter pin in.
    8. Install your new bushings.
    9. Install the new custom pins in your hinges (Remember to put install the pins from the top on the bottom hinge and from the bottom on the top hinge).
    10. Bolt your doors back on and line up the marks you made on the hinges with the marks on the doors.
    11. Make sure everything lines up and WA-LA! Yer done!
    12. Finish yer drink and have anuther to celebrate a job well done! /forums/images/graemlins/waytogo.gif
    13. Turn off yer tunes if want to or turn 'em UP if the mood strikes ya! /forums/images/graemlins/peace.gif
    14. Remember to check your cotter pins cause if they break and you don't pay attention to it, the pins WILL work themselves loose on the bottom and WILL FALL OUT ON THE TOP!! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif Thus, yer door falls of and you look like a fool! /forums/images/graemlins/histerical.gif
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    EXCELLENT IDEA!!! That's exactly the type of info I was looking for. /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
    Thank you!! /forums/images/graemlins/peace.gif /forums/images/graemlins/thumb.gif
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I did mine a little different but works the same. I used the replacement pins you get in the brass bushing kit. It has splines that I ground off so i could pull them. The bottom one goes in like normal and the top goes in upside down. You do wear out the brass bushings a litte faster but no biggy.
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    DAMN SHANE!! Thats EXACTLY what I did!!
    To The Freakin tee!!!!
    was we drukin to geter dat nite???
    /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  9. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    SAWEEEET! I'm a big fan of visual aids! /forums/images/graemlins/peace.gif
  10. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I did that on the 76. The doors are a little heavy, But i can pop them on and off by myself. I am going to do the same with the 73. Took me about 3 hrs to do. But, I didn't have front fenders on when i did it. I lined up the doors AFTER I modified the hinges.
  11. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Cool deal! I hope it helps ya! /forums/images/graemlins/waytogo.gif
  12. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Great minds think alike bro! /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
    Thanks for adding a pic. I don't have any. I usually start crankin somthing out and THEN I think "man, I really shoulda taken some pics"! /forums/images/graemlins/rotfl.gif
  13. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I'm thinkin about runnin tube doors on all four of my entry/exit points.
  14. chevyfumes
    Feb 24, 2000
    38,584
    266
    [​IMG] /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/waytogo.gif
  15. 4xcrazy
    Oct 31, 2003
    9,471
    5
    I was killin myself laughing at that thing when i saw it, couldn't stop laughing. /forums/images/graemlins/histerical.gif
  16. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Dude you crack me up /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  17. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  18. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    this mod seems vaguely familiar...
    /forums/images/graemlins/grin.gif
    j
  19. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    I did it on my truck, but my problem is I have power windows and locks, what a pain in the ass it is to feed the damn wires back through, I need to figure something out for the wires and it won't be so bad. Or get non-power doors, lol. The cotter pins are kind of a pain to get in/out sometimes though and I didn't use any washers and used factory hinge pins.
  20. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Remove the sleeve that the wires run threw from the door to the body. Then cut the wires and add quick disconnects to the wires so when you pull the doors you just disconnect the wires.
    Harley
