Quick release doors?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sageman, Jun 13, 2003.
  1. sageman
    sageman Registered Member
    Sep 27, 2002
    40
    Calgary, Alberta, Canada.
    Does anybody have doors that they can take off and put back on in a quick and easy fashion(SP?)
    I will be daily driving this unit and the weather could get nasty here in Canada... so if anyone has a system let me and others know! /forums/images/graemlins/k5.gif
  2. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    my door pins are easily removed. I did this so i can swap back/forth between the factory doors and my tube doors. Its pretty simple, you basically just buy some longer-than-stock door hinge pins, cross drill them so u can put a cotter pin through em (so they dont fall out!) and ur set. I welded a washer to the top of my pins so they are easier to remove. Here is a pic at webshots that shows how mine work...
    door pins pic
    j
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    There was a pretty in depth thread covering this a couple of weeks ago, do a search... [​IMG]
  4. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    yeah, you'll prolly find pretty much the same response and pic from me. /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
    j
  5. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
  6. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    why do you need that bottom washer?
    are the doors going to fall up?
    i would think just remove the pins, and just stick a piece of metal down the holes....large enough they there is no wobble...and stick a pin in the top and your done?
    why the bottom washer tho
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I think he uses it as a handle to pull the pin out easier.
  8. mud390
    Oct 31, 2002
    1,210
    You've got it! The washer is there to make it easier to put the pin in and take it out. More surface to hold on to instead of just the pin itself.
    Kris
  9. tecton
    Dec 1, 2002
    1,553
    WV
    oic
    im going to do this later this summer whenever i get time
    very cool
  10. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    other guys nailed it. settling from vibration + the weight of the door can make a door pin pretty dang hard to get out, especially if it hasnt been removed in a while. The washer is super handy, just stick a philips screw driver or pair a pliers in there and you have MUCH more leverage over the pin to yank it.
    j
  11. ShitownK5er
    ShitownK5er 1/2 ton status
    Nov 7, 2000
    121
    Shillington Pa
    Yeah i want to remove mine but i have power windows/locks has anyone made or bought a disconnect plug that worked? i tried making one by useing male/female plugs but theyed get all mixed up and turned into a big hassle so i just wired them back together.
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    get some of those touching contact pins, they work great /forums/images/graemlins/thumb.gif
  13. mud390
    Oct 31, 2002
    1,210
    You might want to look into RC car battery connectors. They are two wires per connector and dummy proof. You might also look into quick release connectors. If I remember right, Summit or Jegs has these. Just a thought.
    Kris
  14. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    Trailer plug, just put the side w/ the exposed pins on the door side and the covered ones on the cab side so you dont short things out.
  15. Blazn88
    Blazn88 Registered Member
    Dec 11, 2002
    83
    Northern California
    go to Summitracing.com and buy some of their Posi-Lock connector. Those things work great. All u do is twist off the ends, put in you wires and fray them out a little and twist the ends back on...
  16. SickboySS
    SickboySS 1/2 ton status
    Nov 24, 2002
    154
    Auburn Ma
    i second the idea about a trailer plug...quick and simple...if you need more wires, they have the flat 5's (4 covered 1 exposed) or how bout just some bullett connectors?
  17. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    As long as your not color blind it would work /forums/images/graemlins/grin.gif
    Realy, yes, no prob the multipin connectors just make hook up simplier.
