quick release ignition wire on starter
Discussion in 'The Garage' started by 13lazer, May 6, 2006.
  1. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
    i was tuning my 383ci and adjusting my starter shims and i noticed that the ignition wire terminal on the starter solenoid has the same exact thread as the ac delco spark plug at the top where the plug wire snaps onto it. i threaded the nubb from the spark plug onto my solenoid ignition terminal and crimped a connector from an old plug wire to my ignition wire. i eliminated the annoying eyelet connector and that 5/16" nut and insulated my ignition wire with an old plug wire boot. now my ignition wire snaps on to my starter like a plug wire snaps on to a spark plug. this has eliminated all of my burned up wire, bad connection issues i ever had on my starter. i thought i'd pass this tip along. i like the way the wire is insulated from the exhaust and that it snaps on the solenoid very securely. i can post some pics to clarify my point if anyone is interested?
  2. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    sounds like a cool little fix. Yeah I'd like to see the pictures
  3. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I would like to see some pics, sounds like a good idea.
  4. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    thats neat and all, as long as it stays tight enough on the threaded stud :D
  5. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    Props on the creativity... :D
    Honestly, I think it's better to use a quality, shrinkable ringlet and an insulator myself... Just spray down the whole connection with Corrosion Inhibitor or terminal spray once the ringlet is tightened, then slide the insulator over it..
    But you certainly get an A+ for ingenuity on that one... Keep up the progressive work!
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Very clever!!! :bow: :bow: :bow: :bow: :bow:
  7. 13lazer
    Dec 30, 2004
    115
    San Pedro, CA
    here are some pics i just took with the boot installed. its a tight squeeze so i couldn't get a better angle. it's as secure a connection as my plug wires and they never rattle loose.
  8. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Nice...
