Quick roll bar "Q"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Jul 25, 2002.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Quick roll bar \"Q\"
    Found an ad for a "factory" roll bar from a '75 Blazer.. did they come equipped with a factory bar and will it fit in my '76.. seller is only asking $20.00.. is it worth it.. Thanks
  2. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Re: Quick roll bar \"Q\"
    Someone is going to be selling one to me from this site for $125. I'd get it if I were you...
  3. rcpilot
    Feb 22, 2002
    507
    Central Cali
    Chris.. so it will fit into a '76 w/ minimal prob's??
  4. Grim-Reaper
    7,385
    Atlanta
    It will fit a 76 no problem at all. Might even have the bolt holes for it. It was an available option through 77. There are two styles. One has a bever short kicker leg that hit the floor with in front of the wheel well. It will also have a tab that bolts to a hole in the door frame. Not sure if you will have that bolt hole and no easy way to add a bolt in there. The other the kicker leg is longer and goes to the top of the fender well. I don't think it has the tab for the door frame.
