Quick shackle flop question.
Discussion in 'The Garage' started by K5MONSTERCHEV, Apr 11, 2004.
  1. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    About how many degrees does a shackle flop raise the pinion?
    I have 8" springs, 56". Thanks!
  2. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i would estimate 6-8*
    in a blazer, the shackle FLIP is usually pretty close to correct driveline angles if using a rear CV shaft. in a pickup, you may have to rotate the axle back down to get a proper driveline angle.
    it is impossible to say for sure, it depends on whether you have 52 or 56" springs, different lift spring height, and what shackle FLIP you choose will vary the angle.
    you could pull out a calculator and a tape measure to come up with a close estimate.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I concur, only have 4 inch lift, but pinion came from nearly pointing straight ahead, to being aimed at transfercase, I run a CV now. /forums/images/graemlins/k5.gif
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
