Quick Steering Question. . . help!
Discussion in 'The Garage' started by BowtieRed, Oct 25, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Ok, my dad's TJ, (sorry) has really stiff steering lately. I jacked the front end up, and turned the wheel. just as hard. power steering makes it easier, resevoir is full. it's not the power steering. i cannot turn the steering by the tire, with the front end off the ground. what could it be? i'd like to fix it soon if it's simple, so if you hae any ideas, they're much appreciated. thanks.
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Disconnect the drag link with the front end jacked up and see if the tires will turn easier. If so the problem is in the box...if not you just eliminated the box.
    rene
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i'll do that tomorrow then
    think it could be in the column? i hear a noise in the column like a bad bearing makes almost, or could it be a worn ball joint or a knuckle?
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I know its stupid and obvious but is everything greased?
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Could be in the column. To further isolate stuff you could disconnect the rag joint and try the wheels by themselves with the box attached and then the column by itself. The column by itself should move very easily...
    Noises in the column would make me think that would be the problem area...
    Rene
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    probably, this problem came on over the course of a week, and didn't used to be present at all. i'll check the box, ball joints, and knuckles tomorrow.
    thanks ya'll
  7. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    also make sure there isnt TOO much fluid in the p/s resevoir..
  8. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Here's what I've done:
    Loosened the adjusting bolt on the steering box, and now i can turn the wheels until the steering box catches, so therefore the problem is not in the lower end of the steering (drag ling to knuckles). I can also easily turn the steering wheel until it catches in the box. therefore the problem is in the box. I want to check if it is low on gear oil. I took the four bolts on the cover off, and the locknut on the adjusting bolt- but can't get the cover off. how do i get that cover off?
  9. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Are you talking about pulling out the sector shaft? Never noticed a Heeps steering box before... but if its a saginaw box... pull the 4 bolts, the pitman arm, and be sure the wheels are pointed straight. The tiny-est bit off, and it will hang up in there. /forums/images/graemlins/wink.gif
    Hope that helps...
    -Dan
  10. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ok, sounds good.
